DSP wiring help
  • 2
630
806
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Califmike33
Califmike33
California
Califmike33
    May 31, 2024
    May 24, 2024
