Subwoofers rumble when radio is turned off
All4Cannabis
So I have a Pioneer GM-D9601 2,400w amplifier with 2 10" 150w peak 8 ohm kicker comps.The power and remote wire is ran directly from from the battery to the amplifier. The remote wire
runs to a toggle switch on my dash so can turn the amp on and off whenever. If the amp
has power when I turn my radio off and not my amplifier my subwoofers hit continuously. They also hit for a split second if I hit the kill switch. Does anyone know how to fix this issue???
Troubleshooting 101. Verify you have very good ground and power connections.
Disconnect your signal input wire/s from amp. Still getting rumble? It's an amp issue. No rumble? It's your head unit or the wring, Reconnect signal wires to amp. Disconnect signal wires from the head unit. No rumble? Head unit. Rumble? Signal wires.
If signal wires, try running an alternate set away form where yours are mounted. Repeat above tests.
Once you identify source, post here.
What kind of toggle switch? Lighted switch? Rating?
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
410
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
All4Cannabis
All4Cannabis
Montgomery, AL
ThxOne
just call me KeV
just call me KeV
