How much power do i need
  • 6
Bass so loud it HZ
I m needing help on the cheapest and most effective way to push 4k rms .i have a stock 120 amp alternator .had a xs power 6500d battery but it recently went bad on me .does anyone have any rocomendations on what i should get.i was told two d4s lithium 6.0s with a stock alterntor would power it.im trying to go as cheap as possible and would rather not get a new alternator as im planning on buying a new vehicle soon.
Those batteries are hot garbage. The $800 you were going to spend on them you could build a 40AH bank of Yinlong or a Headway super beast with money left over.
I think you are going to need an HO alt of approx 300amp and a couple good sized AGMs in my opinion
Thats what i figured .i just put in for a quote on a 370 from autotech they seem to be a little cheaper then mechman and singer.
Go easy on that amp with what you have so you dont cook it with the supply you have.
I think im gonna order a 370 amp autotech .ive seen some good revoews on them .and they are a little cheaper then mechman and singer.
You may be able to locate a Local Alt place that will will build what you need/want. I have one I had built (a255) that a local did for me and still going strong a little over 5 years now
Specs https://www.skaraudio.com/products/vxf-15-inch-car-subwoofer
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bobbytwonames
    May 31, 2024
