NEED HELP TUNING
Bryanhrdez00
I have a jl 500/1 slash amp with a epicenter pushing a 12 inch W6 in a ported box and a pioneer avh w4500nex with a 4 channel amp i need help tuning it’s my first ever sound system don’t know much about the crossover on the stereo or amp/epicenter settings
All the door speakers are fine I just feel like the sub should be playing better then it is and sometimes it just cuts out idk if I’m pushing it to much or if it’s for the same reason that it’s not tuned correctly I’ve heard another set up almost the same as mine and it sounds way cleaner
These are the settings that JL Audio recommends for the 12w7, but I think should also work for the 12W6.
Cutting out is usually a sign of bad power connections. I assume both amps are on a distribution block and sharing a ground point. Is the full range amp also cutting out?
list ALL gear. electrical upgrades too? what car?
why are you using the Epicenter?
for crossovers, 80hz is a good starting point but depends on your gear
did you set your gains right? heres how. test tones are at the very bottom...
Thank you it sounds way better then it was And I fixed why it was cutting off it was because of bad power because the full range amp was losing power to
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
680
961
Bryanhrdez00
Bryanhrdez00
San Diego
Bryanhrdez00
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
