Enclosure/budget 12
SlugButter
CarAudio.com VIP
4,664
2,146
arizona
Picked up a 150$ sub to play around with from a local dealer. Colossal Sounds extreme 12, 750 watts RMS. Going in 2 cubes tuned to 32 HZ using a 4 inch round port.. Looks decent for 150$.
The sub will be running on an RDS audio 2k, which is 2000 rms @ 1 ohm. Im running it at 2 ohms with this 750 rms dual 4 ohm sub, which should be more than enough.
Testing stains. Probably going with a dark red color with a semi-gloss oil based urethane. Putting in a terminal cup made from a repurposed 1/4 inch thick poly-plastic cutting board and some zinc nuts and bolts.
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
701
SlugButter
CarAudio.com VIP
SlugButter
arizona
chornet44
    May 18, 2024
    May 18, 2024
