Subs are not working but sub is on and subwoofer isn't blown
Jahrome2301
Hi everyone
So I just installed a secondhand JVC KW-X830BT headunit and I'm running 2 10" subwoofers that is hooked up to a Fusion 1000w 2 channel amplifier.
So when I installed the headunit and tested my sounds, I realized that the subs weren't working but the amp is on so I tried a normal speaker and wired it to the amp to see if sound would come out to see if my subs were blown but no sound came out the speaker so I checked over all my wiring and all the wiring was fine. So seeing if anyone had any suggestions what could be the problem😁
What method are you using to send signal to the amp? Do you have rcas from hu sub out to the amp? Did you check continuity before you installed the rcas?
Bummer
As a novice I check the obvious first. Continuity of rcas? Are you able to verify output voltage from sub out? Stats say 2.5v. Verify at rca ends by amp.
Check to see if you have ac voltage on the speaker wire to sub for the amp. If you have already checked the settings on the HU check the gains and crossover on the amp. Try to use a different rca on the head unit and use the lpf on the amp.
You don’t need a splitter. Remove the RCAs from the sub amp then turn the system on and verify w a multimeter that you have 2.5 or maybe 1.25v on the rcas.
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs started working so yeah new RCA cables it is😁😁thank you everyone for helping me.
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
The issue may be the sub box, not the equipment. If you got them prefabricated, chances are you got the wrong size an tuning.
If there is an OEM subwoofer, wire the NVX input to the wires that go to that sub. Then use the NVX RCA outputs to the amp RCA input.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
820
Jahrome2301
Jahrome2301
Kaitaia
Jahrome2301
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
