How do I Bypass my Amps crossover…
Loucious
Hey guys,
I have a Focal Solid 1 amp I use for my 8” subwoofer.
I want to use my head units crossover for it, and bypass the amp crossover…but my Solid 1 has NO bypass/or all pass thru setting.
What would I set the amp crossover at, so I can set the head unit to a 80hz LPF?
Thanks for all suggestions and all is installed and working great.
13
839
How exactly would I do this for after market amp and since factory is 14 channels how would I get close to the factory amp? I hit a curb on...
Please excuse this extra question .. Is there a specified patch lead or compatible bypass harness for the factory amp or would I have to create it...
863
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
6K
187
Loucious
Loucious
Colorado
Louisiana_CRX
    May 19, 2024
    May 19, 2024
