20 Ram Quadcab with Uconnect
  • 2
Junior Member
After I was done installing amps, LOC and sub, it was time to bump it. No sound. Nothing at all. After surfing and many radio reset techniques, we found the load resistors were bad.
So if you are using load resistors in lieu of speakers, do test them before installation.
The frustration of thinking I had burned out the head unit had me cursing in undersized speaker wire.
Curious where, how, and/or why you used the resistors?
I would need them if I replaced my stock 2 ohm speakers with 4 ohm, but it doesn’t sound like you touched the speakers. I’m guessing you installed an amp to drive your speakers that didn’t match impedance?
The OEM radio needs to see a resistance to turn on the amp. When you delete all OEM speakers, you add the load resistor in between the positive and negative as if it was a speaker. From those same wires you splice in the LOC. Now, there are some LOCs that have Ohm matching built in. That is basically it. These 6 Ohms resistors are the same ones used to prevent hyper flashing LED turn signals.
According to Crutchfield, those JLs won;t fit in your dash, can't see why, just what it says on their site. it says those JL's won;t fit in the...
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
949
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Junior Member
Pharr, Texas
