Can i cut a 15 inch enclosure to fit 18s
  • 2
Bass so loud it HZ
I just bought some new 18s and im waiting on a box to be built but really want to bump them asap.theres a dual 15 inch box near me on market place cheap .can i cut the holes out bigger to fit the 18s ? This would only be temporary. Thought about building one but i dont really know how to design a box i never have and i recently moved and all my tools are an hr away. Tia!
If its solid enough, has the airspace for your 18s, and you have a way to make a nice round cut, then sure.
Building a box is pretty simple. I'm sure you can find plenty of youtube videos, or perhaps threads here to give you the details.
If you don't have the airspace for those 18s, then you could damage them, and you'll be wasting your time. With the amount of work to build a box, the running around to buy parts, the cutting, gluing, bracing.... An hr drive is the least of your worries if you have the tools you need. You could do it, but that excuse ranks about a 1.5 out of 10 for how lame it is when you think of the overall picture.
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard for me to fit in my schedule .ive never built a box im pretty sure i could but i dont have the slightest clue how to do a port .ig i could prolly just build a sealed box for the time being ..but i apprecaitte it
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
112
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
Thats a good looking sub. Ive book marked that site. I may try one out for an Xmas present to myself??
50
6K
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
    May 18, 2024
    May 18, 2024
