Question about wiring with ignition and switch 12+ power
bbaker1210
So I’m replacing my cars radio, and in the user manual for the wiring of the new radio, it says to test the radio (before installation) it says the ACC wire and the 12+ V wire should touch the positive pole of the battery and the ground wire should touch the negative pole in order to turn on.
Should I cross the ACC wire and the wire that will be supplying power when I install the radio, or would that drain the battery?
Alright. There are two illumination wires in stock and only one in the new wiring kit. What would I do there?
If you have a multimeter, see which one sweeps the voltage when you use the dimmer knob. If they both do it, choose one and see the function characteristics as you use the radio at night.
I don’t have a multimeter. Should I just pick one and see its function? It is a touch screen stereo
30 bucks on Amazon and you can get this one got one similar and works just fine.
or their other version
the 1st one also has a 25% coupon at checkout and the 2nd one has 5% for basic stuff works fine. I have a 500 dollar fluke that dad got at Mobil Oil for free that I also use and for setting amplifiers I just use the cheap 30 dollar one as it works and it has the same numbers that the Fluke does when I set gains so the Fluke is just used for other stuff at my dads house.
Watch the video pop put up. Those don't put up anywhere near what they claim. Hence why spokey said run it at 1 ohm.
Just ignore Red...he's wealth of useless to dangerous advice...all without knowing what he's talking about
19
Or a 25 and a 30, 25s are just harder to find in stores. I may be able to get one from my local audio installer. I already have to talk to them to...
bbaker1210
bbaker1210
Arizona
Firewalker
    May 19, 2024
    May 19, 2024
