sounds_explicit
2020 tahoe
Non amped
Using lc8i
Front doors and rear doors to lc8i
Front to main in, rears to channel 3
Stock hu, eq setting are all flat. When i went to measure my voltage at rca out at main channel on lc8i I can only get to 1.3 ish volts. Same goes for channel 3 out and channel 3 feeds channel 4 for sub out. How cannj boost my signal a little more? Idk why it would be so low. And turning the dials on the lc8i only raises it either a little bit. So I let them both sit at 1.1 volts... and tuned everything.
Also when i tuned my 4 channel and my sub amp I set the 4 channel with no overlap and the sub channel with zero overlap on dd1+ . Not sure of where to set it or how to actually know where it needs to be.
I feelnlike the system is lacking a bit but it does get down. My volts don't drop past 14.0 which I thought would be even less. So not sure if I tuned everything right. I have no clipping that I can see. Should I be trying to get a better voltage to amps? Redoing gain iverlaps?
Non amped
Using lc8i
