Can't figure out how to put a kill switch on my amp
  • 6
flytyer75
I have a Rockford Fosgate amp with a 8AWG wire from the amp to the battery, with a 50A inline fuse. I want to put a kill switch in and am having trouble gathering information. My thought is to buy a 50A toggle switch and install it. I am not sure if this is the right way to do it. I am also not sure if I put this switch in where it should be placed.. e.g. close to the battery, before or after the fuse. It seems like such a simple thing but the 8AWG wire and 50A seem to push me out of inline rocker switches. Any advice will help. Thanks
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it.
An example why I would use it. One, to shut the bass off quickly if needed, some head units can be slow at this or it’s in the menu.
Two, when I’m testing subwoofers / sub amps and still want to test using music. Sometimes I just don’t want the mids / highs screaming, I just want the bass while doing this.
No idea the OP’s reasoning for it, but that is why I wanted to.
I have tons of spare switches/ wiring. I still plan on doing this, but likely never will? 😆
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
So, to follow up, I got everything working properly again. If you refer to the photos I sent of the amp internals, you can see there is that white...
14
We still need to know what amp is having the issue, make and model. Some mono amps only have 1 preamp input and the other is a output.
flytyer75
flytyer75
Spokane, WA
Deiimos
    May 19, 2024
    May 19, 2024
