Loss of bass
  • 5
Gooch89
Hi guys, having an issue with my audio in my 2006 wrx. I have sound deadened my 4 doors and boot(trunk). Installed jbl gto splits front (6.5") and rear (5.25"), powered by a 1000w pioneer amp(have correctly set gain). I also have a 10" kicker sub on its own amp. The headunit is a grundig. Now the issue I have is, when driving I loose a considerable amount of bass. If I lean forward and down to where my steering wheel is whilst driving I can hear the same bass heard whilst stationary. What am I missing here? Why can't I hear my bass in the correct seating position.
Not loud enough lol
Update, spent some time messing around and set the time delay for the subwoofer to a much longer amount. Also inverted the phase of the woofer. Bass is has improved by a great amount. It appears that the sub was cancelling out the door speakers bass.
At least you found a way to get more out of it. What type of enclosure? Sealed or ported? If ported.. what is it tuned to? Which Kicker 10" sub are you using . Are you running a 1 ohm or 2 ohm final load? I know that C10 SCV 4 are prob kind of old, and may not have changed much. But back in the past, I put 4 Kicker C-10s in a 3.6 sealed enclosure on an old Autotek Mean Machine 66HC in a cousins 78 single cab Chevy truck and they Slammed!!
It's one of these bad boys. Comes as a package. I believe it's a ported box.
This is only a 150 rms sub. I havent found what it is tuned to. I would recommend looking at a mininum of a 600 rms sub up to 1k rms @ either 1 or 2 ohm and an amplifier to match with a ported enclosure tuned from 32-35 htz with sub and port facing rear of trunk which generally yields great result for trunk placement. Others may chime in
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Nice find. Generally always an issue at a Break /Spliced area. Ikeep approx. 4-6 inches of wiring on each side of a main Fuse to refresh to Clean...
13
The next time it happens check the voltage directly at the Boss radio. If it has 12v on both the red and yellow wires and the black wire is...
650
If you had to run new wires that tells me the old head unit was fine and that there is a break someplace in the wiring you have now. I would be...
27
Gooch89
Gooch89
Australia
BassErex
    May 19, 2024
    May 19, 2024
