FM and AM stop working after 20 sec-15 min
  • 2
AudioAnomaly
AVH 1330 NEX
Worked great for 3 1/2 years.
Now the FM and AM provide no audible output at all after somewhere between 10 seconds to 15 minutes. There’s only silence when this occurs. No static. No intermittent audio. Just silence and failure to detect a station to stop on. Radio starts working again after vehicle is turned off then cranked back up. FM/AM doesn’t work again if I only power cycle the radio.
ALL other head unit functions perform as they should. To include Apple CarPlay and Bluetooth connection. I’m
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is cutting out or the antenna may be on it's last leg.
Best way to test is if the wire to the antenna (blue or blue/white) has power when the issue occurs.
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
982
Those subsonic frequencies make a difference in how music sounds. Hearing the music and also feeling the subsonics adds a depth to music. You hear...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
Thats Great man. Its always nice to hear what the actual culprit was in these threads. It deff helps the next individual (y)
AudioAnomaly
AudioAnomaly
somewhere
    May 12, 2024
    May 11, 2024
