Aero port or ports
Awardwinna80
Texas
Hey, new to the group. I'm building a box to fit behind the seat in my single cab truck. I have buckets and a console. That said, I have room , and proper airspace to fit my nvx vcw 12 in the center. Sub has to be center. I'm wanting to use aero port on the box. Either single 4 or dual 3. In my thinking, the dual three inch, one on either side would function better than a single 4 inch. Thoughts
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on both ends. I’ve used straight pvc before with no flare and it always has port noise. In a car trunk it’s likely not a big deal because the trunk hides the port noise, but in a center console box you’ll hear all the nastiness.
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
995
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
692
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
862
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
834
Awardwinna80
Awardwinna80
Texas
SlugButter
    May 12, 2024
    May 11, 2024
