Almost embarrassed to ask šŸ˜³
  • 6
spokey9
5 time International Booty Bandit Gold Meldalist
4,995
1,842
NE AR
There's a 6 channel Rockville amp for $40 near me. I've heard working bur it's got 6 pyle coax on it and the setup sounds like trash. I'm kind of interested in grabbing the amp...are Rockville complete garbage? I really just need a clean signal I can eq through my dsp.
I bought two 4 channels back in 2015(?) to run temp until my FSD 4 channels were back in stock and I was impressed for the $80 or whatever I paid for them. They did get very hot though.
Theyā€™re not bad. If you have realistic expectations and the amp works properly itā€™s worth 40$. Pyle speakers are kinda bad, but you get what you pay for there also. I bought 18 dollar Pyle 6.5 inch coaxials to put in my shop Bluetooth stereo paired with a small sub and they sound ok. I donā€™t allow frequencies below 100 HZ to play through them though, which makes a big difference. They donā€™t like low frequencies. You can get good sound quality from almost any equipment if you purchase the right equipment, install it properly and know a little about crossovers and how the EQ works.
Its $40 bucks. if it works and looks decent Id snagg it up. Try it out, if i liked it Id run it for a bit and later sale it off if I got a replacement????
I've got a wendy and a 4 channel rf already running...as much as I like to simplify things I really don't wanna take the time rerunning the wires off the tweets unless it's a good amp šŸ˜‚ I'll just be patient til the right 6 comes along
Not sure I am reading you correctly but there is no reason to use the leads from the OEM amp if that is what you are talking about. Normally you...
spokey9
spokey9
NE AR
spokey9
    May 8, 2024
    May 8, 2024
