Ignition/ACC low voltage?
JoeWood
NY
I'm trying to put in a new head unit on a 2007 Chevy Silverado 1500 Classic, and for some reason, I'm only getting about 4.5v when car is started. The fuse seems fine, not sure where to look next.
Anybody have something like this before?
Is this on both power wires? The constant and the accessory.
No, the Constant is 12v. the accessory is low, so low that it doesn't actually trigger the head unit.
If I bridge the constant to the accessory, everything works. Just the Accessory isn't working correctly.
I thought I had got a reading of 4 volts, but now every time I try I'm only getting like 0.5v.
Did you get the correct wiring harness for the HU? If not.. Its possible the pin connection isnt making full contact in that slot
I did yeah. The OEM Harness was frustrating because the pinouts for the aftermarkets had the wrong layout. I have it correct. I'm measuring low voltage out of the acc wire probing at the OEM harness. Same issue with the OEM radio.
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
715
Some at DIYMA and other places have tried this Oscilloscope as well and got good results shockingly for such a cheap unit...
Thanks for the clarification. Fuse boxes generally have some blank spots you can tap into.
u may be referring to the yellow wire and red wire. But there's a voltage drop just at the on position. So no signals come in via antenna. Or...
JoeWood
JoeWood
NY
JoeWood
    May 8, 2024
    May 8, 2024
