Help with car amp/speakers
Vi Percent
So I have a car amp that states 100w rms at 2ohm and/or 75w rms at 4ohm for each channel and 300w rms at 2ohm for the sub
So I want to run my sub at 2ohm but want my speakers at 4ohms
And from my understanding 2ohm rms is basically double the power of 4ohm
So if that's the case why is the manual saying it's
75w rms at 4ohm and not 200w?
And also does my amp control ohms or is that just solely based off the speaker?
I'm still learning all of this jazz
The speakers are where the Ohms ratings come from. So the amp will play at what the speaker rating is.
Most often times it is as you say; when the resistance halves, the power doubles. Not all companies rate this way for some reason but it is nothing to worry about.
You must be using a JL Audio amp, my full range amp has those exact ratings. It is an XD200/2.
No that's not the case, and 4 ohms is not a perfect double of the resistance, of 2 ohms. So even though your question should have been why isn't it 50w (not 200w), that's not how it works because of design and materials.
Your speakers are deciding the resistance.
Yeah my amp is a JL Audio xd700-5v2, so yeah the speakers I have are rated for 175w rms each at 4ohms, so will my amp actually do 200w at 4ohm or will it limit it to 75?
As mentioned before, you have the ohms to power backwards. The power doubles as the ohms drop. If your amp says 100@2, it would be 50 @4ohm. But as HOW mentioned, there are other variables which is why your amp is rated at 75@4ohms. Your speakers will see 75 watts.
There is Stereo Mode and Mono Mode Mixed Mono and Bridged, and a couple others. Most manuals will be a bit vague of explanation ,but these days, the internet has all kinds of information to research to be understood
In Stereo Mode /Full/HPF @4 ohms you will see 75watts rms @14.4v continuous, and @12.5v continuous 60 watts rms from the specs I read
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
600
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
Vi Percent
Vi Percent
Detroit
Silicon oxide
    May 18, 2024
    May 16, 2024
