Mixing ohms
  • 2
bernee69
23
NC
Can I put a 8 ohm an a 4 ohm speaker on the same amp channel? If so, how should I wire them,? I have 2 8 ohm speakers an 2 4 ohm speakers with only a 2 channel amp. Is their a solution for my problem?? The speakers are the same except for the ohms, sundown audio neo pro's 6.5, one set is 4 ohm an the other is 8 ohm.
Assuming the amp is 2 ohm stable, you can wire them in parallel to the amp.
It is I'm pretty sure it is ,sundown audio salt 400.2. An is that one channel with 4 ohms an 1 with 8 ohms, or each channel with 1 8 ohm an 4 ohm ?? Cause I know that the 4 ohm in parallel is 2 ohm an 8 ohm in parallel is 4 ohm. Not sure what 8 an 4 ohm in parallel would be.
Should be fine with that amp. 8 + 4ohm in parallel = 2.66 ohms.
Im not sure if this helps or is the correct way but I have 6.5 mids in the front doors and tweets in the pillars I used 2way 6x9s in the rear...
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
Follow the wiring diagram for the final 1 ohm load for the 6.5s and the 1k amplifier...
bernee69
bernee69
NC
bernee69
    May 20, 2024
    May 20, 2024
