Subwoofer issues
The speaker wire is 12 ga and is new, the sub is rated at 400 watts rms, yes I know 1500 is overkill so I have the amp turned all the way down. I don't know what the max wattage rating is.
What is the Model of the JL Sub? Coil configuration? DVC4 Ohm sub? what vehicle do you have the sub in and what type of enclosure and the dimensions and if ported what is it tuned too?
In my experience, the echo sound is a result when only the positive pin in the RCA makes contact. The negative in the signal may have come off...
@1aespinoza I see, so this audio volume leveling is what I was experiencing tapping into the Bose sub wires. Well then, I'm off to check out the...
675
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
jws2390
jws2390
Silicon oxide
    May 31, 2024
    May 24, 2024
