Steering wheel controls
  • 2
Bpriceio
My boat has a cabin that is water tight for the head unit, sub, and amps. I put a regular head unit in. I have the round marine remote on the console. I'd like to connect it to the Kenwood headunit I put in. Can I do this via the steering wheel control?
Not enough information. Some remote units are radio specific while others are stand alone.
thanks for your time in replying and the effort you have obviously gone to, my radio only has just one single wire for the steering wheel control...
Did the instructions on the back of the main module not work? They are vague but give you a general procedure.
Update: I emailed Atoto support. They are asking me which wire in this Simple Soft CAN BUS controls the steering buttons? If I knew that, I...
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
I'll give that try, setting the LPF on the head unit sub outputs to 80Hz and leaving the HPF at 120Hz. If I didn't set an HPF, what would the...
Bpriceio
Bpriceio
Missouri
    May 18, 2024
    May 18, 2024
