Need wiring help! 2 DVC subs
barkbark
I'm brand new to all this so I did some research and just need some clarification on a few things...
I haven't landed on what amp I'm getting but I will use 2 different kicker amps to use as substitutes for other amps with similar specs.
Attached is my wiring diagram
PART 1
Figure 1(left):
I plan on getting two Kicker 6.75 subs(150w RMS 4 ohm DVC) https://www.kicker.com/comp-rt-6-75-4-ohm-subwoofer with a Kicker amp https://www.kicker.com/CXA8001-800-Watt-Mono-Class-D-Subwoofer-Amp. From what I understand, the 2 positive outputs are connected and 2 negative outputs are connected on the amp because its a mono amp not 2 channel. So given this...
  1. Is the wiring correct for 4 ohm load?
  2. If wiring is good, the amp is sending both speakers 150w each right?
  3. This works?
Figure 2(right): These are the same subs but now with a weaker amp https://www.kicker.com/CXA4001-400-Watt-Mono-Class-D-Subwoofer-Amp.
  1. Is this wiring correct for 1 ohm load?
  2. If wiring is good, the amp is sending both speakers 200w each right?
  3. 200w is fine even if a little higher than sub RMS right?
  4. This works?
PART 2
Important part over, now just some general clarifications.
  1. I've read stuff like 4 ohm is clearer, 1 ohm is louder, and 2 is in between. Is this referring to the ohm load? or sub ohms? Are they even different enough at this power to even matter?
  2. Is it best to match the ohm load to the subs ohm or does this not matter?
  3. Given the two setups, the cxa400.1 is still less taxing on the car's electrical system right?
LASTLY: (if both systems work as I expect it to) Which out of the 2 setups would you choose?
PART 1
Figure 1(left):
  3. This works?
  4. This works?
PART 2
Okay here it goes.
First, not going to cover wiring example 1, Don’t worry about series for now; it’s not relevant here given the equipment you want to use.
Example 2 gives you a 1ohm load and is correct.
  1. If wiring is good, the amp is sending both speakers 200w each right?
Technically the output will be equal to both (all woofers in this setup) and will be the sum total of the amp’s output at any given volume relative to the amplifiers rated power devided by the total number of woofers. The amp does not see 1, 2 or 5 speakers, it sees all woofers as one speaker when using a mono configuration like this.
  1. 200w is fine even if a little higher than sub RMS right?
You listed an 800 watt Kicker amp that is 1ohm stable and it will be fine in this setup, but we’ll cover other options that may give you more for the same $$ or the same for less $$, later. So yes, this amp will work; I just think there are better options for the money. I always run amps that are rated higher than my subs for reasons we can cover later if need be. There are a lot more options at the $299 price that this amp is going for.
This works? Yes, this will work fine.
PART 2
  1. I've read stuff like 4 ohm is clearer…
The resistance rating (ohms) has nothing to do with the amps clarity. Good quality amps are clean, lousy quality amps are not.
  1. 1 ohm is louder, and 2 is in between. Is this referring to the ohm load? or sub ohms? Are they even different enough at this power to even matter?
Ohms are a measure of resistance the amplifier sees (referred to here as the impedance load) after all the woofers are connected to it.
A higher load (like 8ohms) = higher resistance read by the amplifier = lower output from the amplifier.
A lower load (like 1ohm) = lower resistance and the more output the amplifier will deliver.
Any number in-between is relative to the load the amplifier sees as stated in the afore mentioned examples.
  1. Is it best to match the ohm load to the subs ohm or does this not matter?
What matters is that once you know the impedance load of the sub configuration that the amp sees, you just need to be sure that the amp is stable at that impedance load, which this Kicker is.
Let’s not worry about the 400 watt amp, not thinking you're going to use it. ;)
That said, this is where things get a little more complicated. Generally speaking, yes. A higher output amp or the combination of multiple amps output demands current commensurately; higher output, more current (amperage) is needed the higher the rated output is of the total demand for all the amps combined. Exceed the alternators ability to replentish that which is taken from the electrical system and you will tax the electrical system. The numbers aren’t linear or that simple though. It has to do with efficiency ratings and other things that I really don’t think you need to worry about with a 4 x 150 channel amp and an 800 to 1200 watt subwoofer amp and I'm guessing here but I bet that 4x150 is more like 4x75 anyway. It's also not driving power hungry suwoofers either.
Getting a big 3 upgrade and replacing your stock battery with the largest high quality battery you can squeeze under the hood and adding 1-2 farad high quality cap in line with the sub amp will suffice in this scenario. Unless your alternator is really puny, you should be okay. You will want to run 1/0 AWG OFC cable to distribution blocks and the appropriate 1/0 or 4AWG wire to the amps. You’ll need to fuse the leads at the battery (I use quick acting breakers under the hood) and fuses near the amplifiers, even if the amps have built in fuses. It’s more about protecting the wire from catching fire as it is protecting the amplifiers. Fuses/breakers are a lot cheaper than a car on fire!
Hope this helps.
Example to wire Two DVC 4 ohm subs and amplifier stability for either 1ohm or 4 ohm final load
The ONLY way I would ever use these is if you somehow only have holes for 6 1/2" (which would be designed for midwoofers), don't need any more mids that were designed to fit in those holes, and ABSOLUTELY DON'T HAVE room for a 10" or even an 8" slim sub.
They're small, low wattage, and I would take a single 10" over these all day, for several reasons.
Are you mounting these in a door?
What's the rest of the system?
Why are you going with 6 3/4 subwoofers, and not a single larger sub?
Example to wire Two DVC 2 ohm subs and amplifier stability for either 2 ohm or 8 ohm final load, (or 0.50 Ohm of which you will need very good electrical and a 1/2 ohm stable amplifier)
I myself would run a mid sized to heavy ten rather than a pair of 6.5s or 8s for my main sub. Id run some 6.5s in a 3 way door set up or in the Kicks for a 3 way
Love the12volt.com, awesome site!
First off, welcome.
That wiring method is called parallel. With this method, the more speakers you wire, the lower the resistance gets.
  1. wiring is good, the amp is sending both speakers 150w each right?
  2. This works?
At 1 Ohm as described above, the amp is rated 800 watts. So 400 watts each sub. Too much, yes. So you lower the amplifier's output by adjusting the Gain. You want 300 watts for the combined RMS handling of the subs. The formula for that is
Volts = Square Root of Watts x Ohms.
Volts = Square Root of 300 x 1
Volts = 17.32
Set your multimeter to Volts AC, connect the leads to the amp's sub output. Turn up the Gain until you hit 17.32.
Yes to all this, but the differences are negligible until you get into the high end gear, so don't sweat it.
Yes, very important for a long healthy relationship with your gear.
The bigger amp hands down. Bass is addictive, so better to have the power for a future upgrade if the bass bug bites.
Absolutely. Ive been using it for years. Im not sure why its not a Sticky as much as its been used on here??
Because if somebody took the time to make one long sticky for those that are learning, it would cut down on AT LEAST half of the new threads. Then, a few people on here couldn't make much progress on that post count.
Even just writing down "Use RMS numbers and match speaker Ohms to Amplifier Ohms" would cut down 2-3 threads a week. There's a couple people on here that would have so much extra time on their hands, they might get so bored they would have to go and get real jobs.
First off, welcome.
That wiring method is called parallel. With this method, the more speakers you wire, the lower the resistance gets. In your case it will be 2 Ohms. That is 4 Ohms divided by 2 voice coils.
At 2 Ohms as described above, the amp is rated 600 watts. So 300 watts each sub. Too much, yes. So you lower the amplifier's output by adjusting the Gain. You want 300 watts for the combined RMS handling of the subs. The formula for that is
Volts = Square Root of 300 x 2
Volts = 24.49
Set your multimeter to Volts AC, connect the leads to the amp's sub output. Turn up the Gain until you hit 24.49.
Didn’t he say that he wanted to use 2, dual 4 ohm subs? Running both coils parallel then the two subs parallel you would end up with a 1 ohm load. Just don’t want to confuse the guy… ;)
On that note, I'm outta here!
Personally I am curious to who he is taking shots at with the real jobs comment.
You do realize a couple of us are disabled for life correct? Like myself after 122 surgeries & one of the rarest genetic syndromes on the planet. And that a couple others are retired?
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
367
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
483
barkbark
barkbark
California
    May 19, 2024
    May 19, 2024
