Do i need to upgrade my battery and or alternator?
Zach L
I got a stock electrical system, it's got a 150 amp alternator. Not sure on the battery size. But I just got a new amp that does 1100 watts rms at 4 ohms, I'm gonna be setting the gain to get 700 watts rms. I was wondering if I would have to get another or new battery or upgrade my alternator. My buddy thinks I will need to but I'm not so sure. (Battery is 70ah CCA 760A)
if you set it at 700w
700w / 80% efficiency (varies depending on the amp, but that's about average) = 875 w draw
875w / 14.4v = 60.7 amp draw.
(1100w/ .80 = 1375 / 14.4 = 95 amp draw) That's when your amp is maxed out playing full volume. Not sure what vehicle you have, but a factory 150amp alt is on the higher side. My guess is that's a newer vehicle or maybe a work truck.
Your battery should be fine. It's a storage bank, and that should be within comfortable limits.
For an alt, when you are playing that at max volume (700w), you are drawing 60 amps. Between those notes, and songs its drawing much less so that it could recharge. Your vehicle is only drawing it's max, when you have your ac on, electric fans on, lights/brights on, charging ports/cig lighters/ dash lights, turn signals, brake lights. Other than that you aren't even close to using up that 150amps.
I don't think you will need to, you certainly don't need to upgrade either one before testing it out. If you play that on full volume for hours on end, and then notice your battery voltage start to drop, THEN your alternator can't keep up, and you need one that can charge more. If it was me, having a factory 150 amp alt, I wouldn't even bother with either until I KNOW there is a problem. I certainly wouldn't expect a problem with that.
(if you do plan on upgrading the alt, YOU NEED to think about the rest of the system you MIGHT want to upgrade in the future. Then would be the time to buy that 300 amp alt, and not after you buy a 200amp alt, then decide you want another amp. Cheap alts are $200, and good ones are $500+. Don't buy a $450 alt, then in 6 months need a $550 alt).
1000W or so sized amp can typically be run on a healthy stock electrical system. You're working things a bit hard and shortening lifespam of alt and battery, but I shouldn't think you're going to be at the point where you need to start buying into electrical upgrades right away.
Do at least add a large additional ground cable from the - terminal on your battery to a solid and sanded shiny spot on the car's chassis.
Thanks for the info, I have a 2022 kia soul. I didn't think I would need to upgrade my battery or alt but I wasn't 100% sure so never hurts to ask. Thanks a lot for the response.
My car is only about 2 years old. And only around 40k miles. But I was looking into upgrading to the big 3 eventually just not 100% sure when I'll get that done. Thanks for the advise.
they don"t have anything for the G8, and my problem with the install kit is the hvac part. i dont like the physical controls on it, hard to operate
Not that I like shilling my own sales but I have a badass digital designs 5channel for sale in the classifieds. One of the largest available...
What Vehicle do you have? Have you done the Big 3 or any other Electrical upgrades other than just Plane Stock Alternator and under the hood...
893
Zach L
Zach L
Washington State
Silicon oxide
    May 16, 2024
    May 16, 2024
