Getting loud and low with 400w
rc10mike
I b sippin on sizzurp
I currently have a single sealed ID 12 running of the bridged ch5+6 of a D-6.1200.
It sounds good but I want something that can hit the low 25-30hz region better.
Right now I'm thinking ported 15 tuned around 28hz. A Rockford P1 or even JL 15WOv3. I just want the best possible low end with the 400w I have to work with.
Any other ideas or thoughts?
Ported 15 should do the trick. Don't care for either of those subs though. Maybe a Incriminator Level 1 or Dayton Reference. NVX makes decent entry level subs.
Way back in the day I had two 15" Kicker XPL subs (bought them from someone on this forum) run off of a Orion HCCA225 in a 2001 Blazer and it would make the dash and windsheild flex pretty good for 400 watts and a sealed box.
Couple of these sealed?
Forgot to add it's 400w @ 4 ohms.
Also, forgot to add I mysteriously found a single 15 SEALED box in my attic. It's about 3.7 cu/ft internal. Looks like the Dayton 15 would work well with this space..
I don't think I possess the time or knowledge to build a t line lol. It's an SUV.
The basics are actually really easy. You just take the net Sd of the woofer(s), make that the port area (or make it some % over), find the wavelength you wanna tune at, divide that by 4 (1/4 wave), and that’s the line. So say you have 120 in^2 of Sd, then make that port area @ 1/4 of the length of the tuning wavelength, and that’s a t-line.
It sounds pretty easy. I may try it one day when I'm retired.
How about putting th ID in ~2cuft ported and tuned to 28-32hz
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
684
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
I'm stupid. Please repeat what stupid me said that was wrong.
17
rc10mike
rc10mike
Jacksonville, Fl
ThatChevyGuy
    May 8, 2024
    May 8, 2024
