Sony XAV-AX1000 suddenly stopped putting out audio
adriansarajlic
NC
I’m a bit of a noob when it comes to car audio so about a year and a half ago I bought a car that’s been quite a piece of work. Previous owner stripped the entire audio system besides wiring so I bought a head unit (Sony XAV-AX1000) and some speakers and did what I could but after finishing up I had no audio. My boss knows all about car audio so I had him take a look at my work and found out there used to be an aftermarket amp installed so all the current wiring ran to that but of course since it was no longer there I wouldn’t get an audio so he showed me a little work around to rewire the speakers directly to the head unit since I don’t have any subs and the head units amp had enough power to work with just the door speakers. Once I did that I had no issues ever again until 2 days ago I was in the car and made a 15 minute stop and once I got back in the car and got on the road again I noticed I wasn’t getting any audio anymore whatsoever. Nothing out of the ordinary happened at all and every article/thread I read about issues with this unit is about people not getting audio directly after installing but I can’t find anything about suddenly losing audio. Someone please help
Is your head unit still getting power?
Did you try other sources, bluetooth, fm, am, (are you sure you didn't change a setting?)
Turn bluetooth off and try a different source.
If you have a multimeter you can check for AC voltage at the speaker terminals.
You can also try to disconnect the battery for an hour and see if something resets.
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing the same issue? Just a thought.....
That looks like it can work for backup cam for sure, thanks
917
You will have to pull the unit from the dash to view the model # and Serial # either on top/bottom that will have a sticker and usually a wiring...
I have a Sony xav ax5000 that won’t come on when plugged into the truck harness. I have tested it on a 12 volt battery and it will come on that...
688
adriansarajlic
adriansarajlic
NC
huberoy123
    May 12, 2024
    May 11, 2024
