2012 Laramie mega cab
Whats your budget? What are you wanting out of the system? would you be willing to rip all that stock stuff completely out and start fresh?
Hi guys, I have a 2012 ram 3500 Laramie mega cab with the alpine system and was wondering what some of you have done for speaker, amp, and headunit setups. What is the best way to go for speakers and headunit or amp. Show me what you have.
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang and replaced all components including the wiring; and added a amp and 2 subs. Happy I was able to install the system myself, as a shop would have "taken me to the cleaners." Unless you have the skill level to install it yourself, recommend using the Crutchfield application and replace individual components with the existing wiring.
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
632
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
Wiring color code should be ISO, just like American radios. If you get your vehicle specific radio harness, it should have the same colors as that...
Furgis
Furgis
Earl Grey, Saskatchewan
huberoy123
    May 8, 2024
    May 8, 2024
