Rockford Fosgate R300X4 - no blue light
  • 2
r7boatguy
I have 2 R300X4 amps in my boat and the blue light on one of them no longer illuminates when the power is on. On power up, both amplifiers show a blue light, followed by red. Normally, the blue light then stays on. One amp displays a blue light, the other doesn't. However, both appear to work - all the speakers are working.
I can't find anything in the manual about this. I understand that a red light indicates some sort of short, but is the lack of a blue light also indicative of a fault?
Thanks
Thanks
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at times. Electronics dont last forever, but it is also how they are protected and stored as well from the elements.Out of the sun,heat,winter,rain, and moisture,ect. Pull it and throw it on a work bench and test it on a good 12v battery. Is the amp under warranty????????? If so, you can send it back and they can repair it or give you a replacement
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
r7boatguy
r7boatguy
Florida
    May 16, 2024
    May 16, 2024
