Need advice on swc control module.
  • 2
TexanSound
23
texas
Well i got my radio installed at the shop i work *general automotive not a quick lube as i didn't have the time or correctl tools. set the swc to what it needed to be prior to, it doesnt work so had a cel come on for a reoccurring problem, hooked up to the scan tool *that cost double digits. Well the steering controls work. Now next step
i have PAC's RP4-FD11 along with a kenwood deck. I sware on the dial 1 was kenwood. Wrong its 3 so i changed the dial still doesn't work. Reprogramming didn't seem to work and it is receiving commands when a button is pressed. Just not output. So wiring issue? I have 2 unused plugs a gray thats vehicle harness and a 4 pin on the swc module.
Everything works the deck plays sound *main goal as stock failed a long time ago. Also pretty expensive from ford. 2.5x as much as the kit i bought from crutchfield.
I should learn to read instructions more vs once or twice.
Its a 2011 f150 xlt with sync package.
361
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
475
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
823
TexanSound
TexanSound
texas
TexanSound
    May 18, 2024
    May 18, 2024
