Amp/Sub pair help
bulatz
Hello im trying hard to learn myself about this stuff but i just don't get audio numbers.
I have a Rockford fosgate punch p200.2 amp
it has a bridged power 200 x 1
i need to replace my 2 subwoofer speakers and i went to local car audio shop
they wanted to sell me 2 pheonix gold 12 rx2 speakers which are 12 inch 200w, was about $450-500 im trying to get something little cheaper perhaps and do it myself.
i cant find a 4 ohm 12 inch 200w speaker on crutchfield they are all 250-300w should i buy from a different place then or can i still get 250-300w speakers or is that to strong.
Just to tease:
Amazon product ASIN B0007XV5FY
$120
2 of these wired at 4ohms each:
$140
One of these at 4 ohms bridged - 370watts per channel:
$69
Total: 329 plus tax.
Some systems are out of reach, for others there's MasterCard!
What size is the box you have right now? You are worrying about the wrong thing. Speaker wattage ratings are relative. You are not going to find a decent sub that only TAKES 100 watts. The rating is there to guide you regarding the application you have and what the speaker is designed to withstand. Any 200 to5000-watt woofer can be driven by your RF amplifier. Efficiency is going to be the more important specification if you decide to keep that amp.
I would contact Crutchfield support to get their suggestion. I would take a chance 250 -300 watts. Your amp can drive (100 watts RMS x 2 at 2 ohms)
Just to tease:
$120
$140
$69
Thats pretty Dirt Cheap for a sub stage!! These subs are still available
The amp is used, but you still get a 1 yr warranty provided. I recently ran across this page as it popped up on my Ebay stuff/Alerts.
What vehicle do you have, or want this to go in? What Radio or HU do you have?? You may need an LOC? id put the RF amp on the front stage and get a component set
The problem as I see it is: You are trying to build a sub setup for the lowest wattage you can possibly find, all because you have an amp that's worth about $50 new. 200w x 1 is nothing. It's not enough power to drive any real sub. You can definitely find lower wattage subs that are in that range, I know kicker has some but why? That amp is not designed for a sub, it's just (technically) capable of a really, low powered one.
Do you want a sub or not? You're going to spend more to find one for that low wattage, then you could spend just finding a package deal.
If both of those settings you listed are RMS, then you can make it work, and your amp should give you most of what the sub can do. Even that small of a sub, you're going to leave some on the table.
Stop wasting your time with the 2ch amp if you want a subwoofer.
There is really Vague information left on the Table here that could be very useful to determine just exactly what you are trying to accomplish? And what kind of real recommendations can be made for examples as followed;
1= What Vehicle- Year and Model?
2= Budget?
3= What Kind of Radio =Brand,and Model#
4= Stock Alternator,? How many Amps? A 110or 130? What type and size is your battery(CCA,CA,RES)? Lead or AGM?
5=What size enclosure do you have and what type? Ported or sealed? Pics would Help.
6= what Subwoofers do you have Now that need replacing? Make and Model #
There are several SVC4 ohm Subs out there. We could recommend several. Polk Audio has some really decent SVC4 ohm Subs. American Bass has some even.
7= Are you happy with running that type of sub stage? That Ohm Load and that kind of power?
8= Do you want a louder sub Stage?
Amazon product ASIN B01MTYBUOR
Amazon product ASIN B00TSUDOYM
Amazon product ASIN B07W1C6Z6D
Amazon product ASIN B00JDUIK8W
Amazon product ASIN B01MEH098I
There are Subs all over the Internet with a little time spent to search for your budget and for what will fit in your existing enclosure. You may even need to do a little cutting to get a new sub in or filing down? Subs All over the Place on the Internet
Makes sense I use the amp and sub cause I got it free and came with my first car lol I've had them like 15 years never had a problem it bumps good enough for me I guess maybe I'll just buy 2 new subs same kind of the one that blew out they only 75w Fosgate then maybe I'll get upgraded amp/subs later thanks for help
Don't mind the (affectionally known as) BASSHEAD zealots. That system that I recommended at $329 and some change will put out TONS of bass for daily driving pleasure, LOTS! That amp on sale for $69 puts out 370 watts of power bridged x2. That's the same as a 740 watt monoblock!
Run with it and then come back and share how awesome it sounds, I think that you'll be impressed!
Did something very similar for my grandson, he LOVES it! He's running a GM-D8601 to a dual 4 ohm, 12" NVX around the same price, wired to 2 ohms. He never comes close to pushing it all the way and that pioneer amp puts out 500 watts at 2ohms. After using the 2 12's you had and moving to that ported box (of which I matched to the performance of the 12's I suggested) would be surprised if you were not blown away at the difference.
I'd look at running one of these on that power
I've built several inexpensive HT subs around that driver and other GRS woofers, they are surprisingly well-made!
454
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
611
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
619
bulatz
bulatz
florida
    May 11, 2024
RedRyder18
    May 11, 2024
