COMPLETED I need this spacer adapter
  • 2
terryracing86
missouri
These came with adapter kits for 90s Chevy trucks. Would anyone have just the angled spacer part they would sell? Here’s a pic of what I need. Either burgundy or black
I believe that the LC2i has a fixed subsonic filter at 33hz, that will affect the low end too. THe LCi2 pro has a set filter at 22 hz, better...
24
178
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
131
472
terryracing86
terryracing86
missouri
    May 18, 2024
    May 18, 2024
