Bracing MDF
  • 5
The port and the subs should be on the same side (Yes, that is the speaker baffle). This allows the sub and the port to couple acoustically. In instances where you can't, then the opposite wall would be the next best thing. 2 evenly spaced (unlike the picture) braces should be placed equidistant from the middle and sides internal internal braces would be fine. Like this (but spaced as noted and with the sub placement in mind, at least one in the middle):
1 large flared round port is best as it is poses the least friction for moving the air and the dual flares like a Precision port or aero port, reduce chuffing (wind noise or farting) ;)
For the two of the BlackBrick subs you're going to use tune to 32Hz:
The following measurements' include considerations for the woofer, port and brace displacements.
Slot loaded box:
4"Wx10"Hx14"D slot loaded box:
You'll need a 5.75 internal cubic feet. I always recommend a 3/4 inch roundover edge on the extremal port area.
6"Dx10"L Round flared precision port port box:
You'll need a 5.5 internal cubic foot box.
For determining how to cut the port length, follow these guideline.
* - The value for Flare Length Port Required is the overall length of the flared port. If you specified more than one port for the Number of Ports value the Flare Length Port Required value will be for each port.
* - For the 6" Precision Ports cut the center tube 6 inches shorter than the Flare Length Port Required value.
Gonna get a couple of the black brick brickouse 12's. My box can be max 16" high and 39" wide. Depth is to be determined accordingly to the volume airspace needed. If the subs and port need to be on the same side then that will be great. I will fire them into the cabin through the cutout behind the rear seat.
You gots the volumes/configurations above, have at it! Sounds like it's going to jam!
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
some dude
    May 18, 2024
    May 18, 2024
