HU and RCA input sensitivity
is there a problem if my head unit outputs 4v while the amp rca input sensitivity is from 0.2-2v only?
No, but it's rare for an amp to not have at least 4-5v input sensitivity. You'll need to keep the volume on your HU 3db below it's maxed unclipped output.
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
666
No make or model number on it? Do you have an exact picture of the rear and all its glory?
664
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
584
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
754
7saiin
7saiin
Bahrain
    May 16, 2024
    May 16, 2024
