RCAs picking up alternator and signal noise
  • 2
edikecske
Dorog
Hey, I recently swapped my Pio MVH-S520BT (non mechanical) to an 80PRS. Because of its longer body the RCAs are real close to some signal processors inside my dash and I keep getting little popping sounds while braking (when it sends the signal to the brakelights I guess) and also alternator noise. If I pull out the HU from the slot, all of it goes away.
Any suggestions what can I do to stop my RCAs pick up noise? They are 3x shielded, twisted Ground Zero cables tho, I didn’t expect to deal with this.
Thanks in advance!
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or board available that blocks RFI. I know of wallets that have this feature. Maybe you can acquire one and try it out.
68
So i got a 1.5ft Stinger 9000 series rca and i cant get none of the four twist locks to come off. I have had sets of these before and not had...
955
edikecske
edikecske
Dorog
    May 12, 2024
    May 11, 2024
