RCA cable confusion
Alex prior
Hey people I'm looking to buy this head unit for my BMW 1 series and it says it's got a sub RCA output but the diagram doesn't show me one and I was wondering if maybe it's called something else? I'll put the pic of the diagram. Oh also I want the sub RCA just for a single amp/sub setup nothing fancy. I know I can use the rear RCA outputs but then I wouldn't get the full control of the sub from the head unit. The RCA cables start on the diagram at number 12 onwards. Any advice appreciated
Some head units have switchable rca outputs. Meaning that you can go into the settings and change the rear rca output to be a subwoofer output instead. Read the manual to see if this is the case for your unit.
Was thinking the same. Or maybe read USB and if dyslexic like me, read it SUB!
I hope this is the case because not being able to control the sub from the head unit is frustrating enough but then on top of that you will always be changing the subs bass when messing with the EQ. Is there an easy way around it like a RCA to RCA sub adapter?
Inline with the sub input to the sub channels, EQ with the LCi, use the remote to attenuate the volume on the bass channel.
Offer the guy $43, he sold one to me for that price.
You could also do the same wit a little less flexaibilty in mounting options for a lot less on the remote half of this sugestion:
I'll look into this thank you very much. On the upside I found a video of a guy installing the head unit and he has the exact green sub cable that I need with the RCA wire harness. So I think they just forgot to show it in the product photos? It is in the description of the product under RCA cables it says "subwoofer out RCA". They just didn't photograph the sub cable for some reason in the product listing.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
It's really hard, almost impossible to induct noise into RCAs. All you need is a simple set of shielded RCAs. Some home audio guys once did a...
19
Yep, the subs don't move at all when both RCA cables are plugged in. I updated the firmware this morning. Unfortunately it didn't fix my issue...
33
6K
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
674
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
595
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
756
Alex prior
Alex prior
New Zealand
    May 18, 2024
    May 18, 2024
