Noob question here…
Hanzo the Great
Hey everyone! I am going to attempt to hook up a sub in my 18 impala. I have a factory Bose speaker system in the car already and I want to add an amp for the new sub. I am assuming that there is a remote wire already going to the factory amp. Am I able to splice off of that remote wire and run it to the new amp as well or do I need to do something different? I really don’t want to have to take my dash apart to get behind my head unit. Thanks in advance!
You got it right. Only thing I would suggest is to crank up the volume on that Bose system. Ascertain if the bass subsides as the volume increases. If it does, you will need a bass restorer. The LC2i Pro has Accubass. It is a bass restore program. Some users have reported difficulty setting it up, so shop around to see if there is one with a simpler user interface.
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
The link is from JL audio. It’s a how to set amp levels. The process of setting levels is the same for whatever amp.
Hanzo the Great
Hanzo the Great
indiana
    May 16, 2024
    May 16, 2024
