popping noise
  1. B
    Crackling and hiss in radio
    Hey guys, I just recently installed a new stereo in my car and (after getting the wiring right 🤦🏻‍♂️) I’m getting a constant hiss in all speakers, and a popping noise when the volume goes to zero. When I go in the back to check the wiring, I sometimes get a loud crack/pop when fiddling with the...
  2. J
    2010 EX-L New speakers, new problems
    My driver front speaker would occasionally kick out when the weather got hot, so I decided to replace the front and back speakers before that happened this year. I replaced them with some decent Infinity 6.5s. The backs are great, but now both front speakers with make a pop sound and then...
  3. M
    Need Help with popping noise.
    I don't know if this is the right place but I hope it is. So my problem. I installed a head unit with a monoblock amp and 2 subs. Everything was fine. About 3 months later I installed 4 aftermarket speakers and a 4 channel amp with new wiring. Everything worked fine for like 3 months and then 2...
  4. T
    Sub popping noise
    Hey everyone! I'm having a problem i cant seem to figure out. I have a Kicker zxs1500.1 powering 2 cvx 10" subs in a custom tuned box. Whenever i turn it up with heavy bass like dubstep or something it makes a random, loud popping noise. Like in the middle of a long bass drop it will be like...
  5. F
    Door speakers popping when amp shuts off.....
    Here's my issue. Whenever I turn off my car, or power down my head unit, my door speakers pop. This seems to be a direct result from the amplifier loosing power, as they pop exactly when the amp loses power. What I've done: 1. Originally, due to me having a system on a factory radio, the...
  6. B
    Brand New Alpine S-Series Component speaker makes popping noise when being used
    My front right channel speaker is an Alpine S-Series 6.5" Component speaker which is connected to the JVC KD-R900 Head unit no amps. When ever i try to play any music slightly loud or with any bass in it the speaker begins to crackle or pop. It isn't soo loud that you can't hear the music but it...
