01 Ford Taurus headunit help
  • 3
Chronicnuggs
texas
Hello, I got an 01 Ford Taurus and I'm trying to hook up a new radio headunit, but the wiring hardness in the car that was used for the old radio doesn't match up to the new radio? And the harness they gave me doesn't match color wise with stock one, so I wouldn't be sure on how to splice them? I'm trying to put the head unit in so I can install my 8" Jl audio 3v3 sub
That gen Taurus has the tuner in the trunk of the car. The stock "head unit" is just the face for controls and settings.
The wiring harness that fits your vehicle should be around ten feet long. It connects to the harnesses for the tuner in the trunk, then run back up to behind the dash. Id suggest running your RCA's and other wires at the same time you run your aftermarket radio harness.
Okay so, I rip up the carpet, get to the stock tuner and that is where I plug the aftermarket harness, run those wires to the front behind the dash then splice that end to the end of the new radio connector? And that's it?
OKay I got the headunit wired up and working perfectly, but I started working my sub and got all the wires layer out and hooked Up, but when I reconnected the positive battery wire it always blows my inline 50 amp fuse for the battery wire? I don't know why this keeps happening, I really wanna listen to my subs
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
609
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Chronicnuggs
Chronicnuggs
texas
Shorty Jenkans
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
