05 tahoe amp and subs install
  • 5
Cmlemons02
I need some help.. I spent the entirely of this weekend removing my amp and 2 12s from my old vehicle and installing it in my 05 chevy tahoe. I got all wires ran and everything hooked up, and they are not hitting like they should be. The power light is on on the amp and I can tell the subs are back there but they are not hitting like they used to. The bass knob has no affect at all on the bass. It seems to make no difference weather or not it's plugged in. Has anyone had similar issues when doing an install on a tahoe around the same year?
Double check connections, sometimes there’s a switch for the bass remote. Maybe the gain got bumped? Fuse? Inadequate ground?
Bobbytwonames has a good point too. Check hu settings.
You may need to go to some shows and sound offs/meetings
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
that was a pain... 2.5 days probably removing everything, cleaning entire area and doing it. ive only done trunk cars before this was def a lot...
14
117
Cmlemons02
Cmlemons02
Tupelo ms
audiobaun
    Jun 1, 2024
    May 31, 2024
