1 OHM or 2 OHM???
I would run them at 1 ohm but I would also set the gains with a scope and be smart about it.
I've ran a 1500w rms sub off a 5k at .7 ohms without problem.
It also lowers the amps efficiency and raises the current draw.
692
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
492
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
Ridgeline14
Los Angeles, CA
mmwwjr
