1000.00 to spend
My concern with a sub is having rattles and vibrations even with dynamatting. Stuff like that drives me crazy. Or will I hear a substantial difference using a high end amp on the Sony es coaxials?
Your coaxials are not intended to handle all of the bass. Changing the amplifier is not the answer.
What's your opinion on a alpine 12r series preloaded with a Jl10001 amp?
Type R is a good sub for what it is, not sure about their prefab boxes and not sure if a single type R is going to hold up well to 1000W, you'd probably do fine with half that power and if you like JL, I'd suggest to take a look into the 500/1, they've been a rock solid amp for a very long time.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
795
Lucastire
CarAudio.com Newbie
Lucastire
Chicago, IL
Slo_Ride
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
