1000-1500w SPL Numbers
nathanprice
19
Alabama
I was just curious of what numbers other people running in the 1k-1.5k range without a heavily modified vehicle are hitting SPL-wise?
I'm running 4 12s at ~1300w and did a 143.8 sealed on the windshield on music (because i dont know my peak yet).
Edit: added detail
Oh wow, im guessing the interior is nowhere near stockish
More likely it's a 3500+ W amp, high impedance at burp frequency and efficient.
Going by clamp numbers I reckon most wall or SPL builds would be over 150 in the 500-1000W range.
Personally I built a 15" and box for a friend that did high 144's at 42hz powered by JL 500/1.
When I started competing I did 2000W and under class and could burp 148.6-148.7... pair of 15s on DC PAI2000 (same board as the old Sundown 2K)
I'm running 4 12s at ~1300w and did a 143.8 sealed on the windshield.
A Team SounDrive member does 147.8db on 497w sealed on the dash. 100% stock interior, no deadener.
Makes sense.
Thats awesome, very efficient build!
146.x with 2 15w3's in the back of a s10 blazer from a MTX 81000 amp. I'm the one that got that score. Course, that was long ago.
I'm just guessing but at 1400 rms and 2 SA12's in a walled civic. I would be surprised if I didn't break the 150 mark. I'm sure I did but I don't have a meter and I don't have the car anymore. Did all that on solid electrical , plenty of 14v juice
SA 12-D4 x2 Old School PPI amps & 31 eq, Pioneer HU, Focal fronts, Mechman, 4/0 & 1/0 everywhere,Interstate batt x3 6cuft 28Hz
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
778
nathanprice
nathanprice
Alabama
lowriderram_95
    May 18, 2024
    May 18, 2024
