1000 watt amp (550@4)-(1000@2), 2 ohm sub can i just leave it at 2
You can run one coil, but power handling will be lower -- not 1/2 as many will claim -- more like 3/4.
You can also short the open coil, but that has a big effect on t/s parameters, basically making it a different sub (I can't recall the specifics).
I have a new kicker cxa1200.1 amp and the new mono kicker amps advertise themselves to be 1 ohm stable. But the owners manual says it will still only put out the same 1200 watts rms at one ohm as it does for two ohm. But only 600 watts rms at 4 ohm.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
797
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
Disturbance
CarAudio.com Newbie
Disturbance
Detroit
BCotrell
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
