12'' RD Sonace with Coil Rub
  • 4
cman0655555
1. Product:
12'' RD Sonace with FI Soft Parts. Has Coil Rub!
2. Specs:
Top quality audio equipment: Revolution Design Audio
[FONT=&amp]The V.2 is what we always wanted the Sonance to be, it has impeccable sound quality with solid output both in small ported and sealed enclosures. The V.2 has many upgrades over the original like a newly redesigned motor, taller stronger voice coil, Stiffer cone, and improved suspension to name only a few. The durability, sound quality, and output make the Sonance V.2 an all around champion of subwoofers in its class.[/FONT]
[FONT=&amp]Features[/FONT]
  • [FONT=&amp]Available in 8/10/12/15/18” models[/FONT]
  • [FONT=&amp]500/1000 watts RMS power handling[/FONT]
  • [FONT=&amp]Dual four ohm [/FONT]
  • [FONT=&amp]Available in dual 2 ohm flat wind with additional cost[/FONT]
  • [FONT=&amp]Pure custom SPL version available[/FONT]
  • [FONT=&amp]Three layer durable foam surround[/FONT]
  • [FONT=&amp]Dual stacked high power magnets[/FONT]
  • [FONT=&amp]Hot forged 25mm tall t-yoke[/FONT]
  • [FONT=&amp]High excursion motor[/FONT]
  • [FONT=&amp]Cast basket[/FONT]
  • [FONT=&amp]Poly/cotton spider bolted to the basket[/FONT]
  • [FONT=&amp]High temp glues used[/FONT]
  • [FONT=&amp]Black anodized aluminum former[/FONT]
  • [FONT=&amp]2.5” diameter voice coil[/FONT]
  • [FONT=&amp]Ridged paper cone with Kevlar fibers[/FONT]
[FONT=&amp]Specifications[/FONT]
[FONT=&amp]12" D4[/FONT]
[FONT=&amp]FS[/FONT]
[FONT=&amp]29.9 HZ[/FONT]
[FONT=&amp]RE[/FONT]
[FONT=&amp]7.2 OHM[/FONT]
[FONT=&amp]QMS[/FONT]
[FONT=&amp]5.8[/FONT]
[FONT=&amp]QES[/FONT]
[FONT=&amp]0.494[/FONT]
[FONT=&amp]QTS[/FONT]
[FONT=&amp]0.455[/FONT]
[FONT=&amp]RMS[/FONT]
[FONT=&amp]8.93[/FONT]
[FONT=&amp]CMS[/FONT]
[FONT=&amp]0.099 MM/N[/FONT]
[FONT=&amp]MMS[/FONT]
[FONT=&amp]265.7 G[/FONT]
[FONT=&amp]BL[/FONT]
[FONT=&amp]27.5 TM[/FONT]
[FONT=&amp]SPL@1W[/FONT]
[FONT=&amp]87 DB[/FONT]
[FONT=&amp]VAS[/FONT]
[FONT=&amp]42.8 L[/FONT]
[FONT=&amp]XMAX[/FONT]
[FONT=&amp]19 MM[/FONT]
[FONT=&amp]XCOIL[/FONT]
[FONT=&amp]52 MM[/FONT]
3. Description/Condition:
The sub does function but has coil rub that is audible. I wouldnt reccomend running it as is. It will need a recone! You can get them directly from rd, fi, and im sure psi as well. Last time I checked the fi recone was around $60-70. Your getting a nice motor with a good basket.
4. Price: : $60 obo+actual shipping and paypal fees. If your local we can just meet up or I will drive to you for a small fee. Shouldn't cost to much to ship as it doesn't weigh that much. Not really looking for trades but doesn't hurt to ask.
6. Pictures:
BUMP! New Prices/Options. I am going to disassemble the sub to lower the shipping cost.
Motor only 50 Shipped (will fit in a usps medium flat rate box about $11 to anywhere in the US)
Motor and 12’’ Basket 65 shipped (I can probably fit the motor and basket when they are separated in a large flat rate box from usps as well. The shipping for that is around 15.)
Pictures back up didn’t realize I moved them. Have the motor and basket currently separated. Can do 40 shipped for the motor. Make some offers would like to get this moved as its just in the way and taking up space
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
617
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
3K
Okay i found one under b stock on alphards shop site but unable to actually place order grrr
cman0655555
cman0655555
Carlisle, KY
cman0655555
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
