resko1 10+ year member
<<< 8" TC1000 LMS S3
15" TC Sounds 3hp neo
3Hp neo motor non-linear
15" TI basket
Quad 1 ohm 8 layer coil wired to d2
2- medium spaced TC spiders dual sewn leads
15" pro5200/ aura 1508 cone (proto) Dont let the cone fool you. Will reach 2.5"-3" peak to peak.
FS-34.32hz
QES-0.443
QMS-7.863
QTS-0.419
VAS-56.15L
MMS-269g
Bl-21.04tm
Le-2.13mH
Re-3.381ohms
xmax- 28mm
xlim-34mm
Pe-2000w
SPL-92.87db
I have a folded horn design for this driver that requires about 7-8cu total box but shows a 148-150db level, 1 meter from the horn mouth on 1500w rms. I have included one pic of the hornresp parameters and one of the hornresp 0.5pi loading response. Should be a 2db cabin gain in car and have a response that extends down about 8 more hz.
For those that dont know what hornresp is its a horn modeling program created by david mcbean and EXCELLENT software, but tricky to use.
New/rebuilt sub. Tested for functionality and TS parameters pulled. Box required is too big for my 300zx.
300 plus shipping.
Only trades i would consider is for a double din headunit.
Shipping is from 53081. Box will be 18x18x16 and 35#
15" TI basket
FS-34.32hz
QES-0.443
QMS-7.863
QTS-0.419
VAS-56.15L
MMS-269g
Bl-21.04tm
Le-2.13mH
Re-3.381ohms
xmax- 28mm
xlim-34mm
Pe-2000w
SPL-92.87db
300 plus shipping.
