150db trunk car Little attempt at big bass
your all getting trolled
Say that to the guy on here that holds a record w/ 6 PYLE (YES PYLE!) Square 10"!!!!
no bracing and the box looks calc wrong port etc and what amp do u know that only needs 2 70 amp fuses for 40000 watts
4000 watts if lightning hits it or u run over an extension cord at the show
where did u get the math for the box/ port ??
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
720
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
lilboom
Car stereo for fun
lilboom
ca
Bettr n' Revrse
    May 16, 2024
    May 16, 2024
