150db trunk setup
next year im gona run my amp @ .5 once my electrical is stellar to squeeze 150..not rocket science
Got my xls in and wired down to .5 see what the aq is made of //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
this entertained me a little bit haha
all you gota do guys is buy sundown woofers and a 4k amp, build a box slightly smaller then what sundown recomends and pop a port in it and its gunna do 150's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif all ive been doing for 3 years //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The guy builds bad*** custom subs, I'm pretty sure he knows a thing or 2 about what works in certain situations. He may not be a hard core competitor but thats no excuse to shrug off what he says.
Awesome that he builds custom subs. That means NOTHING as to how much he knows about trunk setups. By your logic, all mechanics are also expert nascar crew chiefs.
Building woofers does not by extension make anyone an expert at spl trunks just like building engines doesn't make anyone an expert on professional racing. Logic > you.
The man has spoken :v
Your buddy has the cobalt with the 2 z 15s right? Help me out with the design for my cobalt and 2 z 15s
Anton did the box design iirc; Pure Pressure Concepts he's not really doing open designs as far as I know (when it was last brought up on the MNBass head facebook)
Help a brotha out lol. I'm trying to decide if to stick with the 15s if it'll fit or do the 12s
Well they WILL fit, hence Jamie Waddles video, just a matter of getting them in, you need to remove your rear seats (maybe even front) and put it in through there.
lol jamie did his own design work. i held boards for the most part and gave ideas thats all. just build it lol
---------- Post added at 01:27 PM ---------- Previous post was at 01:26 PM ----------
jamies does 152's.... and plays LOW
Shits quiet //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
720
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
casey_anthony
casey_anthony
United States
bumpinexploder
    May 16, 2024
    May 16, 2024
