160 amp fuse?
  • 6
Somchine13
Noob: My BRZ 1700.1 amp just came in today and doesn't have any fuse attach with it. The manual says it will need an external 160 amp fuse. I looked on ebay but couldn't find any 160 amp fuse besides the Siemens fuse 160 amp 3NA6-136-NH1-gL/gG, which doesn't even look like ANL fuses at all. Am I looking at the right amp fuses? I'm lost, HELP!!!
Just curious if anyone has ever put the 160 mill sundown deadner over some 80 mill cld .I'm talking about the kind you have to use a torch on...
166
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
357
6
470
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
757
Somchine13
Somchine13
St. Paul, MN
mast240
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
