160 watts enough for E8?
  • 5
Although it may not do it full justice, just make sure to put them in a significantly smaller box to boost power and output efficiency
Don't listen to this. Its *** backwards.
Bigger box increases efficiency.
Whoops. My bad. I had a late night and morning. Threw up something I didnt recognize around 9 a.m. Had to two a couple Ambiens around noon. Sick as a dog.
Bigger box = need more power
Smaller box = less power needed
Someone hit me over the head. Im going back go bed.
Sorry you had a rough night!
But quickly, the smaller the enclosure, the more power can be handled and visa versa.
Smaller enclosures aid in mechanical capabilities. Larger enclosures tend to be more efficient, at the expense of mechanical handling potential.
Just curious if anyone has ever put the 160 mill sundown deadner over some 80 mill cld .I'm talking about the kind you have to use a torch on...
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
9
929
Welcome. You have a Crown Vic, Which year cruiser is it? You have a trunk big enough to hold a family of four - why three 8's and not a couple...
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
Let's if i can give my input too. 180 Watts is the maximum power your speakers can handle. And it is 4 ohms. And you're trying to find the...
27
3K
Bassin Buick
Brandon , FL
Bumpin' Goalie
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
