2 channel amp to 2 speakers and sub
  • 3
Joff
CarAudio.com Newbie
Hi, I have what I think is a 2 channel amp used for a sub, now I've connect 2 speakers to that in parrel and I have 2 speakers up front running off the stereo. It's an android stereo and when I go into settings and try to adjust the speakers the sound doesnt come out the front right when selecting? It's in my van that only has 2 speakers up front, I added the sub and it was OK but now I've added rear speakers but the sound is mostly from the rears and hardly anything front the front. Should I wire all speakers to stereo and have the amp just for the sub or any ideas what's I should be doing? Any help would be great
Probably. If you tell us precisely what amp you're attempting to use that might help. Some amps can be run "tri-mode" but you will need passive crossovers to make that work and that is very much out of fashion these days.
I would just run the speakers from the head unit, or buy a separate amp for the highs.
Running trimode on a amplifier is possible, but rarely ever sounds the way you think that it will. ( that is the reason almost no one does it anymore)
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
824
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
Wiring question....using four 4 ohm speakers and one 2 channel amp capable of 2.ohm load... Using 2 ohm stable 2 channel 4 ohm amp to power four...
Joff
CarAudio.com Newbie
Joff
Hampshire
Joff
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
