SOLD 2 IA Deathrow 12s
  • 4
rival904
my house
Death Row Series
Introducing a brand new line of subwoofers is something Incriminator Audio hasn’t done in a while. We decided that 2008 would be the year for change. This year IA introduces the DR, short for Death Row. The DR line fills in the power handling gap that is between the LI and the DP. The DR is geared as much toward SQ as it is SPL, so this would be considered by many to be the ultimate SQL woofer. Like all other lines of IA products, the DR comes STOCK “fully loaded”.
Features include:
• 8 Spoke Black Cast Basket
• 3” 4 Layer Flat Wound Aluminum Voice Coil
• Dual Black Progressive Spiders with Woven Tinsels
• Injected Pulp Matrix Fiber Reinforced Cone
• Dual Layer Foam Surround
• Triple Stacked Magnets with Black Nickel Finish
• Interlocking Aluminum Spider Spacer Assembly
• CILD - Center Interlocking Dustcap
• ADC - Air Driven Cooling
• Nickel Plated Push Terminals
• Wrap Around Rubber Gasket
• 1000 Watt RMS Rated
• DVC 1 ohm or 2 ohm
READ BELOW VERY CAREFULLY
Abused.
One of the subs, the dustcap blew off, it seems like some stuff may have fallen in the gap between the coil and pole peice as it makes some noise when pushed on.
The other one, the coil is black.
BOTH SPEAKERS "POP" ON A DRILL BATTERY
I will ASSUME they both work, but they will both need recones. Im not selling a lightly used sub here, I havent personally used them, I dont plan on using them, I helped a buddy out because he was tight on cash.
I do NOT know what impedence they are, if someone NEEDs to know, I will find out(I didnt have my DMM at the time of me posting this)
Since I have to put a price: $400 OBO for the pair, HUGE OBO
Yes, I am open to trades, offer up
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
677
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
6
967
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
845
rival904
rival904
my house
rival904
